Liked 6 Times in 4 Posts
Any "history" of them splitting/cracking all the way around the sidewall? (Mine have one season on them and are 28.0/4.5-15 I run 40 psi in them)
Liked 459 Times in 90 Posts
I have the same tire. Run 40 psi also on 4400 lb car. No problems in 3 seasons.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 54 Times in 27 Posts
Same tire, 35 psi, no issues after several years of use.
Liked 531 Times in 108 Posts
I've used that same tire for close to 10 years, never had a problem. Hopefully, it was just a defective tire.
Jim Kaekel 3836 STK |
Liked 56 Times in 27 Posts
I have also used that tire without any problems ... Were they new &
did they sit outside ???
Dave Ribeiro 1033 STK |
Keep them away from ozone sources such as electric motors.
It depends also upon how to store them for the winter. I was told by Hoosier, both front and rear tires should be removed from the car, deflated, and stored in a cool dry place out of the path of any sunlight.
Nelson Kowal Stock 345 |
Mine are stored on the car, full of air, off the ground, in a un-heated, attached garage.... very little, indirect sun light... Yes they were purchased new....
Liked 10 Times in 7 Posts
Where did you buy them from?
I read, iirc on Hooiser's website, that tires should be stored with 5 psi and not allowed to freeze. While I don't reduce air pressure, I keep the garage temperature above freezing.
