Old 01-12-2013, 01:54 AM   #1
Lonnie Cox
Default How to adjust the rear drum brakes
On my 76 camaro stocker want to make sure no drag.
Thank You
Lonnie Cox is offline   Reply With Quote
Old 01-12-2013, 09:49 AM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Re: How to adjust the rear drum brakes
First make sure the drums are perfectly round, make sure your return springs are not stretched or bent, and make sure your shoes have even thickness from top to bottom. Use a heavy grit sandpaper to round off the edges of the shoes. Lastly install the drums where the slide on and off with little or no resistance.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 01-12-2013, 10:01 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
What Mark said...... Also disable/remove self adjusters....
Old 01-12-2013, 10:16 AM   #4
Gary Parker
Liked 425 Times in 56 Posts
Once all that is done, tighten the adjuster through the slot until the drum can not be turned. Then back it off until no drag. Put on a couple of lug nuts to make sure the drum stays on tight.
Gary Parker 1617 STK
Gary Parker is offline   Reply With Quote
Old 01-12-2013, 10:17 AM   #5
Dragsinger
Liked 99 Times in 60 Posts
Lonnie,
I suggest removing the self adjusting hardware. You can do that by using a long return spring in each top position. To prevent the adjuster from moving flip that spring end to end. The "flipped" adjuster spring will prevent movement
To adjust, use a screwdriver to raise the spring off the adjuster star wheel.
Also, the above post contains good suggestions. The drum should slide off easily.
Larry Woodfin 471W
Old 01-12-2013, 10:51 AM   #6
Lonnie Cox
Thank You I will take your great advice.
Old 01-12-2013, 11:10 AM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I would like to add 1 more suggestion. On the backs of the brake shoes there are tabs that rest on the backing plate of the rear end. Place a dab of brake grease on it so the shoe moves smoothly and does not cut into the backing plate.
Auto parts stores have a nice synthetic brake grease in a white and black tub I highly recommend.
Toyota dealers have small packets of it too. It is the best.
Chris
chris ok is offline   Reply With Quote
Old 01-12-2013, 02:37 PM   #8
Rory McNeil
On older cars that were made before self adjusters were used, the adjusters had much larger peaks on the star wheels used for adjusting the brakes. The larger space between the points allowed the lower shoe retaining springs to grab the star wheel tighter. You may still be able to buy the early style adjusters new, maybe ask for adjusters for something like a 57 Chevy , and see if they are the same length.
On my Mustangs rear drum brakes, I when I got rid of the self adjusting stuff, I cut down the female end of the adjustors enough to allow a jam nut to fit. Yes, you do have to remove the drums to adjust the brakes, but as long as the jam nut is tight, the brakes will never mysteriously adjust themselves too tight.
NHRA 6390 STK
M/S 85 Mustang
Old 01-12-2013, 11:10 PM   #9
Dragsinger
Good job Rory! I like the jam nut idea. And you are correct about the pre-self adjusting star wheels. With most GM products self adjusters began in 1963.
Larry Woodfin 471W
Old 01-13-2013, 01:41 AM   #10
Liked 5,129 Times in 1,956 Posts
Mostly all covered already...
My opinion is that the aluminum 9.5 x 2 GM drums are worth a few hundredths anyway
