Any of you stock elim. guys/gals using a dual caliper rear brake set-up and why? More holding force when staging the car? Thanks
Liked 534 Times in 143 Posts
Yes to the first question and it holds better at the line for me.
Liked 805 Times in 341 Posts
I always had trouble holding our car on the line since replacing the drum brakes with Strange disk brakes all around. Since adding the second rear caliber it holds very well.
The car is a 69 Barracuda. |
Thanks for the info. So is the procedure to pre-stage, press the brake pedal to a given pressure, engage a 2-step set at an RPM low enough to be able to go WOT off the line? I see a lot of stock elim cars bouncing back and forth during the staging process, but they seem to leave against the 2-step.
You do not want more brake on the rear than the front. Good way to swap ends if you have to lock them up. I have single Aerospace calipers all the way around. I can stall it well over 3000 RPM with the foot brake with no problems. You may have the wrong master cylinder, or wrong pedal ratio.
Ed Wright 4156 SS/JA |
Thanks Ed ................good input. My experience has been in SS so leave off the tranny brake and let her eat. Now with getting back into stock eliminator need to learn new ways of staging/leaving.
TC |
#7 | |
Just bought his master cylinder kit and firewall brace for my model car, and followed the enclosed instructions for re-drilling my pedal.
Liked 275 Times in 76 Posts
Maybe I am missing something, but if you are using a LL it is only active for the front brakes and staging the car. What would it matter if you had 8 rear caliper brakes on the rear? Just a curious 3 pedal racer.
Sean
#9 | |
Liked 3 Times in 1 Post
Wade Last edited by Wade_Owens; 01-10-2013 at 05:15 PM. |
Liked 6 Times in 3 Posts
whoooooaaa! i get it. forget i said anything.
i thought the new craze of 6 and 8 piston calipers where for down the top end.....but not so much it seems. i want to try this now, damn snow....i can bring the rpm up to 4800 now, should able to hit mid 5k with more brake. i still only launch at 3400 during the bracket race, but qualifying would be more fun! Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy Ian Hill GT/FA 1982 Camaro, F/CM 1968 Camaro Last edited by Ian Hill; 01-10-2013 at 04:36 PM. Reason: didnt get it...but now i get it! LOLOLOL |
