Old 12-19-2012, 09:49 PM   #1
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default 1986 Camaro Rear Springs
Who makes the best rear coil springs for 1986 camaro. This is for a bracket car, set up like a stocker?
Ride height cannot be low because of tire clearance.
Thanks Monte.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 12-20-2012, 06:33 AM   #2
al wisniewski
Default Re: 1986 Camaro Rear Springs
Monte, I would figure out what rate you need and go to the Moog catalog and reference the spec section to see what fits your need the best.
al wisniewski is offline   Reply With Quote
Old 12-20-2012, 08:58 AM   #3
Ed Wright
Ed Wright's Avatar
Softest you can find that will hold the car up.
Ed Wright 4156 SS/JA
Old 12-20-2012, 12:32 PM   #4
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Eibach used to make rear drag springs, check them. Dyno
Dyno is online now   Reply With Quote
Old 12-20-2012, 05:44 PM   #5
Monte Howard
We put some Eibach springs on Bob Bullocks car and they worked good, but I don't think they make them anymore.
Al I will check out Moog.
Ed, what do you think would be a good spring rate to start with 200?
Old 12-20-2012, 05:53 PM   #6
Capri
Liked 27 Times in 14 Posts
Monte,
Email Dad.
monymkrssla@aol.com
We should have something on the shelf I suspect with everything we stock.
Capri is offline   Reply With Quote
