Old 12-04-2012, 04:21 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Max Wedge info
Originally Posted by denbreeden View Post
I'm building a 440 stroker motor for a max wedge clone. The car will be street driven and make a few passes down the strip occasionally. I'm thinking of using a hydraulic roller, aluminum heads and of course the max wedge intake. Any ideas on which heads, Eldelbrock or Indy? Intakes, A & A or Indy? Looking at 10.25 c.r., 3.91 or 4.10 gear and running a 727 trans. Any suggestions appreciated, thanks!
Dennis Breeden
Dennis,
It really depends how much you want to spend.
If it were me and it would be primarily a street car I would go with the Edelbrock heads and the A&A crossram with Eldelbrock carbs. I'd go with the 3.91's and a convertor between 2500 and 3000 stall.
If you want to go faster at the strip you'll have to give up some driveability on the street.
JimR
Jim Rountree
