Liked 4 Times in 1 Post
Has anyone actually seen a gain from using these 2 piece, gas ported top rings vs Dyke or a good, backcut top ring?
Thanks, Chris Hardy RET |
I believe so. With the amount Total Seal charges for a set of rings with the ported spacers, I'm certain they have realized a significant gain to their bottom line. LOL
That is exactly what I saw. Zero gain in HP. And Total Seal making dividends. Thanks
Yes Chris, I have seen a gain
Bub Whitaker |
Liked 203 Times in 80 Posts
Which rings did you try,the .047 or the .034?
Mike Fuller 396 STK 3961 SS |
Both .047 (1.2mm) gapless most engines depending on max RPM and .032 (.8mm) have shown gains over all the other top rings we have tried here
Bub Whitaker |
Hi Bub,
Were you keeping your end gaps extremely tight on the engines that you are comparing these gas ring to? Thanks, Chris |
