Liked 783 Times in 195 Posts
Jeff -
Not the same. The '67 Ford is a 1.437x1.563 throttle bore carb. Yours should be 1.563x1.686. |
Dwight is right. Geez...I didn't know Autolite made a smaller 4bbl carb!
Jeff Lee 7494 D/S '70 AMX |
Liked 2,493 Times in 700 Posts
George Thomson who owns Carb. Flow Engineering is a wizard with those
carbs. They take some serious work but are effective when done. He raced a almost unbeatable 73 Mustang H/SA with a 4300 that kicked our B*tt continuously If interested ......I can E Mail his # to you. |
But the '73 Mustang has a completely different Autolite which is a spread-bore and around 750 CFM. Not that George can't be effective on the smallest Autolite, I'm sure he can.
Ok I think we are talking about three differant carbs. here.
In 1967 I believe it was the 4100 Autolite. There was a small one and a larger one. The 4300 was not a spread bore. The 4350 was. |
Liked 79 Times in 11 Posts
the 4300 came out in 1967 at 448 cfm (somewhere in that range) . after that they had 2 more designs that were larger. a 4100 is a flat top carb where a 4300 kinda resembles a quadrajet. and if you can pm or send that contact info that would be great john. thanks,bob.
bob beals 7244 |
