Old 11-10-2012, 01:25 AM   #6
ROY
Default Re: Cooling system pressure
Thank You everyone that gave suggestions.I do not run a T-stat,so no restriction there.The air pocket makes sense,even though I fill the system slowly and with the upper hose off at the radiator and turned so as to be the highest point in the system.I spoke with two engine builders today,they both said it had to be blown head gaskets even though the gaskets do not show any damage!! ROY.
ROY is offline   Reply With Quote
