Old 10-14-2012, 05:48 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Fuel Tank - Best Option?
Ben, it is not problem, many racers run without the foam. It is simply a small fuel tank.
Larry Woodfin 471W
Old 10-16-2012, 06:43 AM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Depending on the size of the cell, there may be up to three sections of "foam" in the cell. That was the case with my 15 gal aluminum cell... Easy to compress and pull out through the fill hole. Easier if you " remove the ring of bolts around the filler cap and remove that hardware" as Dragsinger, said..
