Old 10-02-2012, 10:13 PM   #1
Capri
Liked 27 Times in 14 Posts
Default Re: Shubeck style lifters
Call us tomorrow. 219-861-1214. Sometime after 11 should be good.
Capri is offline   Reply With Quote
Old 10-02-2012, 10:54 PM   #2
HP HUNTER
Liked 372 Times in 129 Posts
Thank you
Old 10-03-2012, 09:13 AM   #3
ron mattson
Liked 67 Times in 30 Posts
check sbc stocker parts for sale.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 10-03-2012, 04:20 PM   #4
FINESPLINE
FINESPLINE's Avatar
S mith Machine was making the Schubeck style lifters the last time I heard. My 2 cents about them is there are better ( safer ) ways to go.
FINESPLINE is offline   Reply With Quote
Old 10-04-2012, 04:00 AM   #5
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Exclamation Re: Shubeck style lifters
I recently broke two smith lifters on my new engine after about 9 runs. All I can tell you is I broke the last Smith lifter I will ever brake! It could have been worst and I could have lost the entire engine. A new set of pistons, cam and tool steel lifters and the problem will be solved. The funny thing is my spare engine has Shubeck lifters and they have never failed. Simply put, no one can afford to destroy their engine with defective lifters! It only took one lifter failure to realize we have a weak link.
Anyone who is building a new engine should investigate tool steel lifters. They will not come apart and cause extensive internal engine damage. Hopefully, the people at Smith lifters can find the reason why their product is failing and correct the problem.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 10-04-2012, 08:50 AM   #6
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Shubeck style lifters
Who makes the tool steel lifters? I've heard about them and don't have a recommended brand name. Will they work with that steel cam I have?
Old 10-04-2012, 11:36 AM   #7
Tom Moock
Liked 10 Times in 6 Posts
Greg, Cliff Sherman makes tool steel lifters that are shimmed up to allow .012 in. of plunge. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-04-2012, 04:00 PM   #8
FINESPLINE
FINESPLINE's Avatar
Greg, Trend and PPPC are a start. Depending on the pressure over the nose of the cam you can get recommendations. I just recently read on another forum concerning these lifters. Mike Jones (camking) of Jones cams can point you in the right direction. Ferrea also markets a tool steel lifter. Depending on your core there are DLC and nitride coatings.
