#1 | |
Liked 262 Times in 124 Posts
I'll be using the stock block and the correct heads for the class but I'll be using aftermarket rods and pistons. Evan has a lot of experience with Mustangs, he'd be a good source for info.
Liked 5 Times in 3 Posts
I have a chance at driving an 87 mustang auto at the autolite nats. Does anyone have a clue what these things weigh?
Liked 115 Times in 5 Posts
I think the index was 13.0 and I don't remember what the car weighed.
Paz, depending on the body style (coupe, LX hatch, LX conv., GT, GT conv.) that a V8 225-hp car can run anywhere from H/FI-F/FI. Also, Bret is correct about running as much gear as you can, as long as you have the motor to pull the gear. There is no sense turning 6,500-6,800, when the stock cam and valvetrain is done at 5,800. The rev range for a bone stock 5.0 should be between 4,200-5,800, with the engine revving to about 6,200 in the traps. With better valve springs and a Stocker cam you can take this higher. Evan
Evan Smith 1798 STK Last edited by Evan Smith; 07-06-2007 at 08:03 AM. |
Liked 776 Times in 199 Posts
I called mine an 87 and it had to weigh 3180 with me in the car in G/FIA. That's 14.00 x 215= 3010 + 170 driver.
Bret Velde 3028 A/FI Cobra |
My friends car is a 100,000 miler stocker with only a few external mods , it has low gears and a 4500 converter. It will run right at the index on a good day. How much improvement would a cam make? any other suggestions? I dont want to show up at a national and be a tenth slow!
Liked 319 Times in 68 Posts
Dennis, I would pull the pan and check or replace bearings and the oil pump, use a standard oil pump no high pressure or high volume. Put in a blueprint cam good valve springs a 4500 converter and 5.13 gears. you will be surprized how fast it will go. Lee Valentine Call me at 203-775-6830 est between 6to9 pm and I'll help you out.
