Thanks for your reply. 4:56s is what I was thinking as a starting point. Are you starting with a stock motor? or do you have a aftermarket peice built? Any info would be grate
Liked 115 Times in 5 Posts
I would not let the stock engine rev too far past 6,200 in bone stock trim. If so you will eventually float the valves and cause breakage. I recommend getting a set of new valve springs with something like 120-130 lbs. pressure on the seat. This will be a simple way to get you a few extra rpm. Use either 4.30s with a 28-inch tall tire or 4.56s with a 30-inch tire.
About 12 years ago I ran 12.74/105 with a bone stock 5.0 in Stocker trim. That was with a T5 manual transmission. I'd go with 1 1/2-inch headers, not 1 5/8. Evan
Evan Smith 1798 STK |
Liked 776 Times in 199 Posts
I ran a G/FIA mustang for four years and I started out just like you guys with a fairly stock motor. I ran 5.13 gears with a 30inch radial. when you are running an automatic you need all the gear you can get because these little motors don't have much torque. Also run the 2.92 first gear in the trans.
Bret Velde 3028 A/FI 03 Cobra |
#4 | |
Liked 262 Times in 124 Posts
I'll be using the stock block and the correct heads for the class but I'll be using aftermarket rods and pistons. Evan has a lot of experience with Mustangs, he'd be a good source for info.
Liked 5 Times in 3 Posts
I have a chance at driving an 87 mustang auto at the autolite nats. Does anyone have a clue what these things weigh?
I think the index was 13.0 and I don't remember what the car weighed.
Paz, depending on the body style (coupe, LX hatch, LX conv., GT, GT conv.) that a V8 225-hp car can run anywhere from H/FI-F/FI. Also, Bret is correct about running as much gear as you can, as long as you have the motor to pull the gear. There is no sense turning 6,500-6,800, when the stock cam and valvetrain is done at 5,800. The rev range for a bone stock 5.0 should be between 4,200-5,800, with the engine revving to about 6,200 in the traps. With better valve springs and a Stocker cam you can take this higher. Evan
Evan Smith 1798 STK Last edited by Evan Smith; 07-06-2007 at 08:03 AM. |
I called mine an 87 and it had to weigh 3180 with me in the car in G/FIA. That's 14.00 x 215= 3010 + 170 driver.
Bret Velde 3028 A/FI Cobra |
