Old 08-28-2012, 01:53 PM   #11
Mark Madison
Liked 32 Times in 9 Posts
Default Re: Revised Ford Pulley Specs?
Originally Posted by Jesse Kershaw View Post
The truth is actually much simpler than the conspiracy theory.
The common TVS listed pulley sizes of 76mm (2008/2012 CJ) and 72mm (2010 CJ) are determined by us using a caliper with a 2.5mm gage ball.
The gage ball fits in the groove and helps determine the theoretical centerline of the belt. Our engineers use this diameter to determine the belt length of the accessory drive system. Thus the 76mm, as we advertise it, is actually the centerline of the belt on the pulley.
Because of this measuring method if you measure the pulley with traditional calipers to the top of the groove the number would be less than 76mm or 72mm respectively.
The pulley's as delivered on the Cobra Jet's and the samples provided to NHRA at the time of production are identical and have never been altered.
For the 5.4L w/2.3L TVS supercharger the following SC pulley sizes are as delivered.
2008 – 76mm w/gage ball – actual minimum diameter = 73.95mm (2.911”)
2010 – 72mm w/gage ball – actual minimum diameter = 69.95mm (2.754”)
2012 – 76mm w/gage ball – actual minimum diameter = 73.95mm (2.911”)
Whipple does not measure like the OE. Their 4” pulley (2010/2012 5.4L engine with 4.0L Whipple SC) is 4” to the top of the rib +/- .010” making the minimum diameter 3.990”
The Whipple 3.5” pulley (2013 5.0L engine with 2.9L Whipple SC) is 3.5” to the top of the rib +/- .010” making the minimum diameter 3.490"
Super Stock racer TIm Kish is intimately familiar with this as he works in the Eaton supercharger division.
Whew, for a moment I thought we had another double secret camshaft debacle on our hands. Mark Madison
Mark Madison is offline   Reply With Quote
Old 08-28-2012, 02:44 PM   #12
GUMP
Liked 2,354 Times in 554 Posts
Jesse,
Thank you for posting. You are a good sport for responding to the craziness that goes on in here in such a professional manner.
Take Care,
Daren
Old 08-28-2012, 03:29 PM   #13
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Originally Posted by gump View Post
jesse,
thank you for posting. You are a good sport for responding to the craziness that goes on in here in such a professional manner.
Take care,
daren
x 2
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-28-2012, 09:50 PM   #14
Thanks for the clarification, Jesse.
I thought it was a bit early to be doing the superceded parts parts thing...
