Old 08-13-2012, 10:11 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: Centering a rearend in a stock supspension Chevelle 1968
Originally Posted by rallye bob View Post
That's what adjustable lower control arms are for..........
i run 30" tall rubber (295/60/15). i have seen where most 66/67 chevelles not only have the rear end shifted to one side (about 1/2 to 3/4") but also have the rear forward on the passenger side about 1/4 to 3/8". i have trimmed the wheel wells to only have 3/8 clearance and dont seem to have any issues with rubbing unless i go to quick around a corner (side wall rubbing - inside left and outter right...only when turning right).
As far as using the adjustable lowers to move the rear end. i would only use the adjustment in the lowers to align the rear end so the car tracks perfect, then use the adjustability with the length to center the tires nicely. then adjust the tops to match, set your pinion angle and i have added a hotchkis 1 3/8 anti sway bar to the rear. i do not use the rubber mounted bars that attached to the control arms, i use tie rods, mounted on the inside of the ends of the sway bar that mount straight up to tabs whelded to the bottom of the upper control arm crossmember. i add 1/2 to one turn of pre load raising the right side of the car. this has made the car launch straight without holding the steering wheel to the 330! now it was only a I/CM running 1.38 60's and 11.05/ 119 but it worked for me.
if you plan on using the adjustments in the lower control arms to center the wheels in the wheel wells, the use the upper to adjust pinion angle and tracking, i figure you will be creating a bind.
Ian
Ian Hill is offline   Reply With Quote
Old 08-13-2012, 04:55 PM   #2
Jim Kaekel
Liked 530 Times in 108 Posts
Just a reminder, adjustable lower control arms are not legal in Stock Eliminator. Adjustable uppers are allowed.
Jim Kaekel 3836 STK
Old 08-14-2012, 01:09 AM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Using a panhard bar is a good way to bind the suspention up on an A/G body. I have had a few A bodys over the years....still have 4 currently and all I have done is trim the inside quarter panel the small amount that the rear is shifted over and done. If they still rub or touch get a hammer and beat some clearance into it....or come to the conclusion that the tire is too big and get some smaller ones. 10 pounds doesnt always fit in a 5 pound bag. My 79 wagon has had 295 50 15's slammed with moroso coils in the rear and 28x12.50 MT ET Streets with no issues at all....no extra bars no nothing. If you push on the quarter panel of the car and the rim/rear end doesnt move with the body or "floats" side to side the control arms are garbage. With solid bushings or good urethane bushings there should be absolutely no rear end movement...peried. And using a radial street tire or radial slick will cut down on tire movement and growth.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
