Old 08-02-2012, 11:01 PM   #1
Joe Toller
Liked 4 Times in 4 Posts
Default Re: Inline six/fox body header?
It's a combo I have, what I have accumulated has been dirt-cheap (trying my hand at a Dime Rocket) and the NHRA HP is wrong (working on that). I'm going to start with the six, and maybe move to a 302 later. I'm following some good advice from Billy Nees, and honestly, I'm a glutton and like the challenge. I have always liked messing with sixes, and oddballs at that. Shoot, I have had this car in and out of my life for the last two years while other projects have come and passed, so I take it as a sign lol...
If it sucks, then lesson learned. I'll just try something different, like the 302.
Mark, being the other Vet whose advice I weigh heavily, I understand the design flaws of the 200 here, but is there something else I am missing? Would it be better to you if the HP was corrected to 115 and not 140?
Old 08-02-2012, 11:21 PM   #2
Joe Toller
Plus, after searching and researching and probably asking enough silly noob questions to drive a veteran nuts, I figured the best thing was to just finally pick a combo and dive in! Gotta learn what this is all about somehow, right?
I'm not afraid to lose, or to fail, I'm afraid to not try and regret it later.
Old 08-02-2012, 11:35 PM   #3
Certainly, but then you'd be down the same rating as the Monza I have for sale with the same size engine and a TWO bbl. carb.
Old 08-03-2012, 12:04 AM   #4
Joe Toller
Good point.
Old 08-03-2012, 12:07 AM   #5
David Lee
Liked 346 Times in 126 Posts
If I were you I would just go bracket race that combo and have fun with it. Do all the suspension mods etc and then drop the 302 in it. Spending the money on a header that may or may not work well is just a waste of money.
Old 08-03-2012, 03:38 AM   #6
VStock
You're facing the same issues I am. I have a car/engine combo I want to run (67 El Camino/230), but the advice here is that it's not competitive. Do I build what I have and want to build, or do I buy a car that has a better chance of winning?
Marty Knox
VStock is offline   Reply With Quote
Old 08-03-2012, 03:46 AM   #7
David Lee
You can win with any car,just talk to Lane Weber or a host of other guys here like Mark Y. The problem is you may spend more money than necessary jsu to get this combo run the number
Old 08-03-2012, 05:40 AM   #8
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Just make sure this combo has the potential to at least run the index if you are going class racing. Other wise it's just a waste of time and money.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-03-2012, 11:40 AM   #9
Joe Toller
This engine combo can run the index in a Maverick or Comet, I get a slightly better flowing head and a little less weight, so I figure if I'm in the ballpark I *should* at least run the index. I personally think it'd be fun as hell to put a 200 with a 1bbl in the 15's. I like the oddballs. At this point, I have everything but a converter and cam, and by scrounging (thank you CL and ebay) and using some used parts I am in it $1500. Granted that is just collecting parts and I have yet to tear into the motor and trans. I found a header unused for $150. I'll probably start a build blog to share, good or bad.
When someone says why, ask, why not?
Old 08-03-2012, 12:30 PM   #10
Joe Toller
If it doesn't run the number, I can put that 200 in another Fairmont with some more cam and carb on the street and then I'll go 302, but not until after I give the six a fair shot.
