Ok guys... have heard alot of different things... Some of the veteran's please chime in... Proper way to wire a one wire altenator, as well as 2 or 4 pole 'kill' switch and rating... Thanks!!!
Liked 1,877 Times in 577 Posts
i always wired mine direct to the + terminal of battery, gets a full charge and does not affect the kill switch. now that being said, my ignition is wired to the other side of the switch, no chance of run on. works for me
Liked 883 Times in 237 Posts
I'd highly recomend including a 3" long ,12 ga. fusible link at each end of the alternator wire ,as it is always energized.
A pinched or rubbed thru wire without the fusible link or any way of disconnect, could spell disaster.
X2. thats the way I did mine except I spliced in a 200 amp circuit breaker just before the battery.
yes, forgot to mention, i did fuse that wire! good point.
Top secret! lol
2 pole, use a good switch, the amps they are rated for can differ. i used a flaming river. also, (my opinion) i liked the push off rod instead of just a switch hanging out the back.
