Liked 32 Times in 19 Posts
The more obvious question should be "Why do you want to pick the wheels up higher" It will slow you down, maybe make you more inconsistent, possibly cause a dangerous turn of the car???? If you want to improve the 60 ft or et then other things should be considered first.
Why don't you just put a bunch of weight in the trunk?
Jeff Lee 7494 D/S '70 AMX |
Liked 244 Times in 26 Posts
Just remember its the car accelerating that causes the wheel stand, not gearing.
I agree with Jeff, 200lb weight bar in the trunk should make you happy.
2009 V/SA Record Holder |
393W
10:5:1 hydraulic flat tappet 239/247@50 541/565 106 lsa AFR 185 Holley 950HP best guess on HP is @500 |
Liked 27 Times in 14 Posts
The Low gear will just get the engine in its "happy" power band faster. Your whole issue could just be simple suspension front end modifications.
Email me when you have time and we can further discuss it. tonyd302@yahoo.com Dad's 65 Mustang does what you want to do with a 289, less power and less torque than what you have and 60fts better. Any video is helpful. |
Liked 1,948 Times in 589 Posts
I would say the carb is too big and too much head. Not enough cam. I dont think its any where near 500 HP with those specs.
Mike Pearson 2485 SS |
