Old 07-16-2012, 04:09 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question McClay Metric Leak At Pan 1-2 Shift Bolt
My lack of energy creates the question.....best way to stop the aggrivating fluid leak at the 1-2 shift adjusting bolt sticking through the pan without upsetting the shift point adjustment. Any ideas out there that will really work ???
Rusty Davenport is offline   Reply With Quote
Old 07-16-2012, 05:56 PM   #2
Brian Fink
Liked 28 Times in 9 Posts
Default Re: McClay Metric Leak At Pan 1-2 Shift Bolt
I had the same issue ; if it isn't too bad clean it the best you can and use Permatex Ultra Black around the bolt /nut . It worked pretty well for me.
Brian Fink is online now   Reply With Quote
Old 07-17-2012, 09:20 AM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
I have the answer. We found a nut with a machined grove for an O RING.
The cost is like $6 I have some call and we will hook you up.
218-426-4009
MEXJOE is offline   Reply With Quote
