Need some help gang, will a 30" slick fit on a 93 fox body ???
Liked 275 Times in 76 Posts
Not unless you do major surgery. Both inside the wheel well and the quarter panel would need modified. Correct backspacing and wheel spacers are still needed for a 28x9 M/T on my car, as the tire is inside the wheel well. The 79-93 are the same shell. If you need any more help let me know.
Sean
I run the 30x9" Hoosier radial on my '87, just one thing you need to make it work. 10# hammer will do the trick.
Liked 27 Times in 14 Posts
All depends on the roll out of the tire. You need something with a short roll out if you dont want to do any major surgery.
Sean, are you running the 10" wheel? I run an 8 1/2" |
10" with 6.5" BS.
29.5x9 fit with this wheel after painting the car. Sean
29.5 radial fits but very tight ... slow when you turn trust me
Marshall Greenwell K/SA |
10" wheel with 6" BS works great with drum brakes, and 6.5" BS for most disk brakes. Like others have said, BFH to the inner wheel well, and about an inch pie cut below the belt line in front and a half inch pie cut in the rear and you will be golden.
Others have run a 8" wheel with 5.5" BS with no cutting...
Shawn Allsup K/S 718 |
Thanks everyone for the help...
Liked 70 Times in 29 Posts
I didn't want to trim mine any, so i stuck with 28's. 8" wheel, 5.5 bs.
What rear gear do you guys run with the 29.5 or 30's? - 5.13?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 79 Times in 11 Posts
4.56 in mine. i run the 8" wheel and had to trim the back of the wheel lip.
bob beals 7244 |
