Old 07-05-2012, 06:36 PM   #9
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Reaction time
Joe I find it hard to believe you even asked this question....
Front end travel will have a big effect on your RT.....and any F-Body from GM is one that can use an adjustable limiter on the upper a-frame....
Limiting front end travel will speed up the RT.....but at some point hook will suffer......
A 3 speed is probably quite a bit different than a P/G and I would guess less effected by front end travel......
I used one on my '69 Camaro in the early eighties.......A nut welded to the upper a-frame and a big bolt going thru it to contact the frame....I messed with it all the time bracket racing......
I can tell for sure there are cars with front end limiters......just look at the pictures......F-Body cars go way negative on camber with no limiter.....If you see a car high in the air with the front wheels at about a ZERO camber angle......it's got a limiter in there....
If your redlighting with full travel..........you have to look elsewhere to slow the RT's........
As good a driver as you are I figured you knew all the tricks.....
Rich Biebel
S/C 1479
Stock 147R
