Old 07-02-2012, 02:12 PM   #10
rawhide
Liked 7 Times in 5 Posts
Default Re: Ford 390 FE help
Originally Posted by Robbie Welch View Post
The cut off bolt came out when I took the cam out. The cam dowel hole is .640 deep now I thought the .325 wasn't deep enough. The only problem now is the dowel hole has a small amount of movemment in it. Like I said it's a street car and he doesn't need the valve train noise. Thanks again for the help Robbie
Robbie,
The dowel pin needs to be snug in the cam. This is important in Fords due to the bolt being in the center of the cam. If it had three bolts off center like a Cheby it would not be as important. If the dowel is loose it will allow the timing gear to move enough to loosen the bolt. When I was building engines I used two dowels in most applications although this was mostly 429/460 style engines.
regards
rawhide is offline   Reply With Quote
