#8 | |
Liked 1,784 Times in 407 Posts
Randy, I'm used to people doing that, no worries. The standard 320 abrasive is fine for "freshen up" honing. The people at Brush Research are real good about getting you what you need. Alternatively, call who ever supplies your rings (I get mine from Keith Jones at Total Seal) and have them tell you what abrasive they like. I usually get one a little bigger than the bore size I plan to use it on, maybe by 1/8". I use my 1/2" cordless drill to run it, and use a fair amount of the Brush Research hone oil. You need to really scrub the cylinders afterward, and the slurry from the hone will be everywhere. I use "purple power" cleaner, cut about 50/50, and scrub with bore brushes and hot water. Wipe it clean with a white lint free cloth, if the cloth doesn't stay white, wash the block again. Wipe it down with a lint free cloth saturated in Dexron.
Alan Roehrich 212A G/S |
