Old 06-04-2012, 09:16 AM   #1
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Default Re: Brake pressure switch
Originally Posted by Brad Zaskowski View Post
If you put it in the front brake line your starting line rev limiter will be activated when you have pressure held line lock on in the burnout.
Not if you install it before the line lock.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 06-05-2012, 12:18 AM   #2
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Yes true.... Fronts brake line will work if before the line lock.
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 08-09-2012, 10:03 AM   #3
Notch1320
Is there anyone who needs one of these switches I mentioned earlier in the thread? I have changed switches, and ill let mine go. Single switch vs. having to buy a minimum of 10.
I paid $67 and only ordered one. (I will take $50 shipped)
The pressure adjusts from 250 PSI to 1000 PSI. Part # 209506
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
