Old 05-22-2012, 03:29 PM   #6
older racer
Liked 68 Times in 26 Posts
Default Re: Clutch switch
hi, you keep this up and NHRA will decide you need a switch. for your information, oldsmobile had troubles with thrust bearings back in 1970 with clutch switch. car had to be in reverse and clutch depressed to start.
just let it go, ok?? no switch is needed !!
older racer is offline   Reply With Quote
