Liked 2,472 Times in 696 Posts
78 is first year of 4 Barrel 318. Do not know why 76 should have diff. ratings.
I think the four barrel combo is better way to go. |
Liked 25 Times in 16 Posts
I think Chrysler rated the engine differently in different cars. Sort of like the Corvette engine was always higher than the same engine in a Camaro. Maybe exhaust manifolds make a difference too?
Mopar 2 Ya! |
Liked 384 Times in 149 Posts
Single/dual exh, maybe different veh's and manifolds as previously mentioned, hard to say. With some fords it was 2bbl carb or 2bbl variable venturi style carb had different ratings for essentially the same engine.
Regardless, both engines are lumped together and are rated at 190hp. (I checked a 76 dodge 318) |
