We put ours on the tranny slip yoke , works fine. ---Trevor
When I had asked computech about the output shaft sensor location they said it could be done but wasnt reccommended as the slip joint does just that, slipping in and out. the movement may be minimal but could cause some issues with the sensors picking up the signal. fwiw.
Dion Hildebrandt 6009 STK H/SA |
Our's is a F body torque arm solidly mounted so there is virtualy no movement. --- Trevor
