Liked 759 Times in 379 Posts
smart decision staying with bias slicks for your bracket car. Smarter yet had you chosen Hoosier.
#2 | |
![]() I may never see the #'s that some of the E/SA cars are runnin' nowadays, but , i still gonna give it a try in the near future. Gotta do it, life is short!! ![]()
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Tried them all on my Chevelle, hated the Phoenix slicks mainly cause they were flat in 48 hours. You must be running tubes and screws.
![]() Hoosier has not only been the quickest tire but they don't leak air! Don't run tubes and screws and never will. |
yea...im old school...tubes and screws... when i make the leap to radials, i wont run tubes... and will most likely go with the Hoosiers , when i do.
#5 | |
Liked 50 Times in 14 Posts
Great car! We run radials with 8" rims, and it has worked out well for us.
Isaac Zane STK 1237 J/SA Buick Apollo Patriot Guard Rider DOOF 43 |
#6 | |
Now that you have the new slicks, focus your attention to the front suspension. There's Et waiting for you.
![]() New control arm bushings (Energy or better) eliminate the bushing being part of the spring like bonded factory bushings. The arms must fall under their own weight. Get rid of the stock or jobber ball joints, replace with Afco low friction ball joints. I couldn't believe the difference there. (again, removing bind and friction) Get the trick front springs, or better yet, weigh the car on 4 corner scales and talk to Afco (these guys might have a better company to deal with for drag coil springs) to get a proper rated spring for your car. (I run the Moroso trick springs, had to cut a coil, then cut a further 1.5 coils to get my car to ride height over the years) Travel is very important for small tire cars, and from what I understand, even moreso with radials. I have over 5 inches of front end travel, I can top out the suspension by pulling up on the fender lip, and when I let go it settles back down to ride height, leaving about an inch between the lower control arm and the compression bump stop. Last time out, the 60' timers weren't functioning, but the final 3 rounds: 6.655, 6.653, 6.649, so the 60's might have been fairly close. ![]() |
#8 | |
Hopefully you find some ET in the work you put into the front end, good luck and glad to help.
#10 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
