Old 04-08-2012, 10:39 AM   #11
sg794f
Default Re: o stock wagon gear question
Originally Posted by kwm View Post
The 4V will not run O/SA The Squire (the heaviest) has a 13.01 weight break with a rating of 305HP it is a natural K/SA.The 2V in the Squire has a weight break of 16.16 and a HP rating of 240 it is a natural P/SA
i think your right about that from further info....this car is the torino 500 wagon that came factory with a 2v, nhra tech said that would be a natural p/sa
so the higher hp 351 4v would put it at j or k ...not sure which gotta chec
i know the car was available with a 4v combo so i think its legal to run
im a s/g s/c driver so all this stock stuff is a little new to me....thanks for the info
kevin
sg794f is offline   Reply With Quote
Old 04-08-2012, 01:08 PM   #12
sg794f
Originally Posted by Jeff Lee View Post
Just to make sure we're on the same page, I see a 1971 Torino SW with a 351C-4V that is factory rated @ 285 HP. Is that the engine you are going to run? Then it is 305 NHRA rated HP, not 300 HP.
Also the specs are a .430"I / .450"E cam, Not .420" / .450".
After looking at what GTXJohn said about gearing (he runs SBM which would have a lot more bottom end than your Clevland), I would start with 5.38's. And you might be right on about the 5.57's.
I believe Pro-Trans will build a TF inside a C4 with better low gearing. Of course that isn't cheap!
For a wagon, I think those are pretty cool. Not Vista Cruiser cool, but I think next best thing.
i think you are correct about the specs....im just a dumb s/g driver, and am learning this stock game. ive already talked to dave and darren about the gearing in the trans and there gonna set it up for me.....im thinking about starting with the 5.38 gears. that seems to be the consensus from what im being told. and we are using the 285 hp motor. just want to have all my ducks in a row before we spend the $$$$ and we appreciate all of the help weve gotten on this forum
kevin sexton
brandon sexton future stock racer
