#11 |
Liked 7,790 Times in 1,744 Posts
Jim, Mike and Tom are correct. If you removed the booster you should mount the MC in the two top holes left from removing the booster. Then raise the pivot on the pedal. If you're lucky, the hole is already in the pedal. I was assuming you had done that already. Still, with a turbo car look at the Vista Cruiser rear brakes.
#12 |
Rick , Whatever you end up with for shoes, take them down to Phoenix Brake and Axle and have them relined with the good material as full length (secondary) shoes..
Mid 70's Malibus, Cutlasses and LeMans mid size cars have the 11x2 shoes...
#13 |
Neil once had a source for asbestos brake lining material. He also used to use material designed for fork-lift brake shoes; very soft stuff and holds great.
Ask Neil...
Jeff Lee 7494 D/S '70 AMX |
#14 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
#15 |
Liked 54 Times in 27 Posts
John Andreotti at Ott's Friction Supply has some soft material that won't glaze and stops well on the top end, yet holds the car well at the line. I believe Abex makes it and it is tan in color.
#16 |
Liked 31 Times in 7 Posts
Thanks everyone for your suggestions, looks like I'm gonna be busy getting this thing to hold. I hated losing class AND second round, so I'm making sure this doesn't happen again.
#17 |
Liked 15 Times in 11 Posts
You went the wrong way on both rear wheel cylinders and master cylinder bore size. Smaller wheel cylinders will push harder on the brake shoes and a smaller bore master cylinder will generate more line pressure, at the calipers and wheel cylinders. Use a one inch bore master, 7/8th inch bore wheel cylinders and check line pressure at the bleeder screws. you need minimum 950 to 1100 PSI at front and should get 800 to 900 at rear without any adjustable proportioning valve in line. Plumb the master cylinder direct to the brakes for maximum pressure.
#18 |
Does anyone know if you can get asbestos brake pads in Mexico?
Nelson Kowal Stock 345 |
#19 | |
Arizona Brake and Clutch 2211 N Black Canyon Highway Phoenix, AZ 85009 (602) 256-7966
#20 |
Liked 138 Times in 51 Posts
If you do some research and ask around, you can still find organic pads and shoes at the parts store. Probably not as good at cold holding ability like specialty relined stuff, but definitely better than the usual semi-metallic. Lightly scuffing the rear shoes with sandpaper to eliminate any glaze build-up helps also. I do it whenever I swap rear tires from side-to-side.
