Liked 795 Times in 210 Posts
Can you put in a battery cut-off switch under the hood if your only using 1 battery ??
I do not have 1 in the trunk. For Stock Elim. Thx |
#2 | |
My battery is in the stock location. But I have a fuel pump cut off coming out of the tail light. It's a fuel injected car, so once you hit the switch the engine shuts off.
Art Leong 2095 SS |
Pete, I use the Moroso shut off that goes right on the battery post. I always shut it off when done for the day or between races, I consider it good insurance.
Doug Blackley 1697 STK |
Liked 348 Times in 152 Posts
Pete -
If you do use a battery switch make sure the amp rating is high enough so you don't burn up your starter - I've seen the cheaper ones that will only carry 400 amps.
Phil Molski PMR Performance S/C 1623 |
x2
2009 V/SA Record Holder |
I have a similar question for stk elim.what if the battery came from the factory in the trunk(2008 pont g5)would they enforce having a cutoff switch
scott fifield |
Liked 460 Times in 91 Posts
x3
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Thx for the replys.
