Liked 9 Times in 2 Posts
I use the Warn 3700 pound winch with my 3500# stocker. It is a great winch and have put them in many of my friends trailers without issues.
Liked 275 Times in 76 Posts
Jim,
That is good to know! One of those things that never see any maintenance. I have had my SW 5000 on my open trailer mounted under the steel bed, and have pulled a 57 Belair 4 door on it several times. That thing was made when metal was metal. It's a tank! My point is you may use the winch for something other than a light race car. Sean
The winch companies recommend that you have a winch with a rating of double the weight of the vehicle you will be winching. I think this only applies if you are dragging a truck out of a mud hole though,lol. I've always used a warn 6000lb unit. It will drag anything onto the trailer, Flat tires and all.
2009 V/SA Record Holder |
I have a Superwinch 2000 lb it pulls the 3000# car no problem. I double up the cable for the 4200# wagon kinda slow but it gets the job done.---Trevor
Liked 54 Times in 27 Posts
That is my thinking also. If the car rolls easily, winch it into the trailer directly. Use a snatch block if the car has a problem. It is also good if someone follows and keeps a 4x4 block close to a rear wheel so it won't roll back if the cable snaps or the winch fails. A coat on the cable will prevent it from whipping around if it breaks.
Liked 797 Times in 211 Posts
Thx for all the replys.
