Liked 15 Times in 7 Posts
Went to start car after long winter build, short story my batttery an xs925 4 years plus old no cranking amps, tested at 13.1 volts but no cranking power.. I run a low comp 340 would like to get a light weight battery (since i am not) any ideas of what works good and will hold up. Thanks in advance for any help
Liked 2,490 Times in 700 Posts
I always go to Walmart and buy a 26 or 56 Series Battery. they ar e about 20 Lbs/$47 Bucks.
and have a Nationwide Warrantee for 5 years. Buy two and mount one in back or keep it charged in trailer in case you make it to Sunday and get to Hot Lap. Be sure mount for Battery is easy to Remove and Replace in case it is needed whatever you chose to use. When are you coming to Vegas? With my attitude I can always use another Bodyguard or two! Last edited by GTX JOHN; 03-18-2012 at 03:12 AM. |
Liked 275 Times in 76 Posts
If you are looking for a lightweight. Odyssey.
The non-metal jacket are the lightest. This is where I bought mine several years ago. Best prices then. Make sure you order the terminals also, if you do buy one. http://www.batterymart.com/c-odyssey...FQvGKgodiHOXIA Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 03-18-2012 at 11:54 AM. Reason: Added info. |
Liked 93 Times in 52 Posts
I dont know if John's recommendation is a dry cell or not, but I also have run the Odyssey pc925 for about 6 years. It can take several complete discharges and be fully recharged without degradation.
The military used to (may still) use them. I had one laying around that I left on the shelf and NEVER checked after 7 years. I put it in my golf cart since the wet cell died and it is still working since last October at Eddyville. It weighs about 22 lbs and can be mounted in any position. I put it on the trickle charger once in a while over the winter and it's always reliable...even on a Saturday night going 6 rounds back to back here locally. It turns over my 12:1 385 stroker like it is 9:1 compression. Clark |
