Old 03-13-2012, 05:25 PM   #14
Default Re: Chevy 2 rear leafs??
Originally Posted by Paul Merolla View Post
I'm glad it worked out for you. I haven't tacked mine in because I wasn't sure if I'd be able to get the bolt out if the washer can't move, since the bolt hits the inner rocker panel. I'll look it over again this weekend when the car comes home.
I believe you are correct, hence the reason for the moveable outer hole..
It's been a while...but I wouldn't weld anything just yet..
