Liked 2,750 Times in 971 Posts
I once had a 426 Wedge block with the AAQA designation and Jerry Stein told me it was a great block because of it's high nickel content. He was right about it being a great block as we went our best numbers with it.
Liked 25 Times in 16 Posts
Well, I don't want to turn this thread into Mopar only. I thought it would be neat to see lots of odd/rare parts from the Big 3 and maybe the not-quite-as-big #4 (AMC). I found some pictures of a Pontiac RA V head. It looks a lot like the Ford Tunnel Port on the intake side. They must have changed the cam lobes on some cylinders since the valve spacing/arrangement is different.
Mopar 2 Ya! |
OK, this is an oddball engine and definitely not a race engine. Ford made some all aluminum V8 engines during WWII (The BIG ONE). The GA series engines started out as a V-12 (thus the 60 degree Vee) aircraft engine (explains the all-aluminum part), but the government already had enough aircraft engines (Allison and Packard built Merlins), but they needed a tank engine. They lobbed four cylinders off to make an all-aluminum V8 of 1100 CID. They had two puny carbs on it. I think it could use three Holleys for a bit more power.
Mopar 2 Ya! |
Liked 783 Times in 195 Posts
Liked 12 Times in 12 Posts
The big 3 made a lot of experimental parts & pieces back in the late 50's through the early 70's...anyone else here remember any other weird stuff.
#6 | |
M/T Pontiac Super Duty Cross-Ram intake manifold... |
