#11 | |
Liked 12 Times in 12 Posts
#12 |
Liked 2,739 Times in 966 Posts
I once had a 426 Wedge block with the AAQA designation and Jerry Stein told me it was a great block because of it's high nickel content. He was right about it being a great block as we went our best numbers with it.
#13 |
Liked 25 Times in 16 Posts
Well, I don't want to turn this thread into Mopar only. I thought it would be neat to see lots of odd/rare parts from the Big 3 and maybe the not-quite-as-big #4 (AMC). I found some pictures of a Pontiac RA V head. It looks a lot like the Ford Tunnel Port on the intake side. They must have changed the cam lobes on some cylinders since the valve spacing/arrangement is different.
Mopar 2 Ya! |
#14 |
OK, this is an oddball engine and definitely not a race engine. Ford made some all aluminum V8 engines during WWII (The BIG ONE). The GA series engines started out as a V-12 (thus the 60 degree Vee) aircraft engine (explains the all-aluminum part), but the government already had enough aircraft engines (Allison and Packard built Merlins), but they needed a tank engine. They lobbed four cylinders off to make an all-aluminum V8 of 1100 CID. They had two puny carbs on it. I think it could use three Holleys for a bit more power.
Mopar 2 Ya! |
#15 |
Liked 780 Times in 194 Posts
#16 |
The big 3 made a lot of experimental parts & pieces back in the late 50's through the early 70's...anyone else here remember any other weird stuff.
#17 | |
M/T Pontiac Super Duty Cross-Ram intake manifold... |
#18 |
Do you have anything off the top of your head regarding legal parts...I guess this could apply to a few stock & super stock classes including pro-stock back then.
#19 | |
Maybe something that was run for a while and then got busted at tech. Parts that pushed the limits of legal but only if the process/method is not something that is being done now. Don't want to get any current rides busted!!! And...like is being shown above, just some cool old stuff. |
#20 |
It was rumored that Jimmy Addison's '67 GTX called the 'Silver Bullet' was a test bed for Chrysler performance parts back in the day...
![]() http://www.dragzine.com/features/car...silver-bullet/ |
