Liked 759 Times in 379 Posts
Global West, Afco and others. That said, the same can be accomplished by modifying poly graphite bushings by adding a zerk fitting, cutting a grease groove in the bushing and turning down the sleeve which is what I had on my Chevelle.
actually no it can't. The poly bushing will still deflect, albeit less than the stock rubber one. The Del-A-Lum style that global west sells will not and will still move just as free if not more so.
Chad Rhodes 2113 I/SA |
worked well for me, footbraking my 3880 lb, Chevelle to a 1.28 best 60 foot with 59% of that weight on the nose.)
![]() ![]() Last edited by 1320racer; 02-29-2012 at 05:46 PM. |
whoopdie f'n doo. I was just pointing out that no, "the same can't be accomplished" by modifying a poly busing. Deflection may not matter to you, but to a lot of class racers it does. Since you aren't one, you don't get it.
oh I forgot, only class racers get it.
![]() ![]() FYI, one of the best stock/super stock builders in the country disagrees with you. ![]() Last edited by 1320racer; 02-29-2012 at 05:55 PM. |
#6 | |
BTW we've all seen the pics of your cars OVER AND OVER....................we don't care anymore
he won't, he's not interested in posting on the net debating with those that think they know.
speak for yourself |
