If the V.E. table & injector flow rate are set up correctly the V.E. around the torque peak should be around 100%, then if you want to lean from 12-1 to 13-1, subtract 10%, should be really close. To go the other way add 10%. 13-1 to 12.5, add 5%, etc.
Works with FAST XFI & Big Stuff3, DFI, should work with any system. Your results may vary. LOL
Ed Wright 4156 SS/JA |
I think my problem is semi solved. Still does the herky-jerky on the brakes.
I went back and used the standard launch control program (non advanced mode) But it doesn't go to 2000 and die there. We will know tomorrow.
Art Leong 2095 SS |
