Old 02-24-2012, 10:24 AM   #1
Mike Croley
Default Re: Anyone test Renegade fuel ?
Actually i know of 11 racers that used Renegade at Orlando , might have been more . And you are the only one that had problems that i know of so there might be a specific problem with your fuel . You mention that you cleaned the entire fuel system after using the Renegade . Did you clean the entire system before filling it with Renegade ? As you know , any residual brand x fuel will change the readings of the new fuel substantially . The testing that NHRA does is very sensitive .
And the huge increase in performance you say you saw when switching back to the fuel you've been using makes me think there was something else going on . You wouldn't see any increase whatsoever by switching from Renegade 112 to C-12 , most likely the opposite in fact .
Send me a PM about where and when you bought the Renegade Fuel , and give me the specifics of the fuel check you say you failed . I will look into it .
Mike Croley is offline   Reply With Quote
