Old 02-23-2012, 10:49 AM   #1
Reed Granrt
Default Re: Tech West Racing Services MSD Upgrade
Originally Posted by Techwest Racing Services View Post
Reed Granrt
Short answer, currently an upgraded analog 6al will out perform both stock boxes from Texas. The advantage a Digital has is a little smoother Soft Touch Rev limiter than the analog version from the testing we have done with in house customers. That being said we are working on an upgrade package for the Digital box that should take the box to another level as well. We have multiple in house testers that have been running the Digital box in tandem with an upgraded box. They all have come back with their staying with analog box until we have the Digital box package ready to roll out later this year. I hope this answer your question, if not you know where to find me!
I have had both types on my dyno with a scope hooked to both and everything I could look at here said that the analog box was better also, but my equipment to check is limited and I did not want to give a false answer.
Thanks for the reassurance
reed.
Reed Granrt is offline   Reply With Quote
Old 02-24-2012, 01:01 AM   #2
Reed Granrt
Reed
Easier to ask then explain a wrong answer! Been there done that......:-) Have a good one & try to stay out of Trouble!!!!!!
I tried staying out of trouble one time, and it wus no fun at all
reed
Old 03-01-2012, 07:40 PM   #3
Anthony Fetch
Hey Pat I just wanted to let you know I shipped my msd 7al2 and according to the tracking it was left at the front door. If you can just confirm that you have recieved it. You can reach me on my cell 732 966 7731
Thanks
Anthony Fetch
Anthony Fetch is offline   Reply With Quote
Old 03-02-2012, 09:12 AM   #4
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Hi Pat
I have stumbled on a Tech release Addendum quoting that the PN 7530T ( among others) will " shut Down unexpectantly" if a resister is not added to the "power on" line while using 16 volt battery's if the hand held PN 7550 Monitor is left hooked up..It states that if your unit has R1 or R2 stamped on the end panel,updates are already installed and this resister is not needed. Mine is stamped R4. I'm taking it that this is revision 4, and the other ones noted were revision 1 and 2...But wanted to verify. Thanks for you time and info, Jeff
Jeff Niceswanger 3740 SS
Old 03-12-2012, 11:59 AM   #5
Chad Rhodes
Pat, wondering if you could give me a hand with an ignition noise related issue?
Chad Rhodes 2113 I/SA
Old 03-12-2012, 06:01 PM   #6
Chad Rhodes
Chad Rhodes
Yeah no problem give me a call.
Thanks for the help Pat, i think that will get me straightened out on the e-shift issue
Old 03-17-2012, 07:48 PM   #7
Mark Lewis
Liked 209 Times in 46 Posts
what is the rpm limit of a 6al box, does it diminish after a given rpm ?
Mark Lewis
Mark Lewis is online now   Reply With Quote
Old 03-22-2012, 07:13 PM   #8
mrshift
Smile Re: Tech West Racing Services MSD Upgrade
Hey Pat , Thanks for the 6T and the testing on the digital 6 plus. Looking foward to get a PWRMAX yes for the late model ,dirt car without a alternator . To all out their I love this site, cant get off of it. And yes even though I help with a dirt track car in PA I too had a drag / street car too, 69 roadrunner 440/6 car running 11.07 . So I really like the site, Thanks guys, Jim, ( mrshift ) P/S I took your advice I got a autozone c839 coil for the dirt car.
mrshift is offline   Reply With Quote
Old 03-22-2012, 10:10 PM   #9
Robert Simpson
Liked 20 Times in 12 Posts
Pat you have a PM.
Robert Simpson is offline   Reply With Quote
