#21 |
Liked 759 Times in 379 Posts
it is so they can also be run as a coil over shock. So you're running coil springs in the stock pockets and not coil over shocks?
#22 |
I'm running a factory type 5" OD spring (Santhuff 180 lb) which goes into the factory pockets. No coilovers.
I don't doubt what you are saying that everything can be controlled with shocks, springs, travel settings. Ultimately, none of those things offer the margin of safety of having a wheelie bar back there if I happen to miss the suspension tuneup. If the track is marginal and I happen to be fighting traction, I'd like to be able to set things up full loose and let it eat and not worry about how high the wheelie is going to be. This car is nose heavy with little/no trunk overhang and I don't run ballast. I would imagine most first gen Camaro stockers run at least some amount of ballast in the trunk. Is there a problem with letting the front end rise and ride the bar a few feet if necessary? What are the drawbacks to a single wheelie bar? Am I still in for problems in good air if I miss the suspension tuneup and it hits the bars?
'67 Camaro 1.25 5.77 @ 118 |
#23 |
I have not come across any drawbacks or disadvantages with the single wheel. However the bar is tunable. That is where the ET is.
#24 | |
#25 |
my good friend with the green small block '69 Camaro could put it on the bumper every pass if he wanted. He doesn't though, rather he tunes the wheelie to weather and track conditions. He doesn't have any weight in the trunk just a chassis/suspension that works nor does he have a wheelie bar.
I'm just informing you that you CAN control/calm the wheelie with what you have as well you can swap in stiffer springs and/or ballast up front. If you want a wheelie bar go for it. Last edited by 1320racer; 02-20-2012 at 06:58 PM. |
#26 | |
Liked 6 Times in 3 Posts
I am sure there are guys running quicker 60's than me with first gen camaro, 9" tires and are able to the control their wheel stands, i am just not there yet. the tires are normally dead hooked, but the track seems to dictate the amount of birds-eye-view i get! 40 Coupe, the car looks great! Ian |
#27 |
Liked 1,840 Times in 428 Posts
Listen to race watcher .He Knows .
Usally charges for this info LOL Hope to see you at a track soon racewatcher
james perrone 1290 STK |
#28 | |
James, you know I know too
Again, if Garret wants a wheelie bar, he'll get a wheelie bar. I'm just advising him as I have been for the last decade, that he don't need a wheelie bar to control his wheelstands. Last edited by 1320racer; 02-21-2012 at 10:40 AM. |
#29 | |
Liked 373 Times in 129 Posts
#30 |
No, the car was sold in 2008 and the 1.28 recorded in 2007.
Here's the launch photo of that run... ![]() the time slip is in the hands of Bret Schlichtig, owner/driver of the car in the other lane, who works for Grumpy at Jenkins Competition. Last edited by 1320racer; 02-24-2012 at 11:47 PM. |
