Old 02-19-2012, 08:03 PM   #1
40Coupe
Default Ken Keir wheelie bars
Anyone running his single bar on a first gen Camaro? If so how well does it work? Also, any pictures of the setup?
Thanks!
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 02-19-2012, 08:09 PM   #2
race watcher
Default Re: Ken Keir wheelie bars
Running 1 wheel for 7 years no problem. They do need to be tuned.
race watcher is offline   Reply With Quote
Old 02-19-2012, 10:06 PM   #3
1320racer
1320racer's Avatar
Liked 424 Times in 204 Posts
Garret, you really want a wheelie bar?
You should be able to tune your wheelies by tightening the front shock extension and adding travel.
http://www.classracer.com/classforum...t=36346&page=3
Old 02-19-2012, 10:47 PM   #4
40Coupe
Not really a want but more of a need at this point. The bars would offer a margin of safety which I don't currently have.
If the surface is well prepped I can do as you say and tighten things down and everything goes to plan.
In order to hook on a marginal track I've got to set the front shocks full loose and full travel, then it goes bumper. If I begin taking travel out or tightening the rebound it starts blowing them off.
I don't see an obvious downside to bars.
'67 Camaro
1.25
5.77 @ 118
Old 02-20-2012, 07:08 AM   #5
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i run Ken's bar. it works well. the installation is an obvious breeze as there is no welding required. i found that you have to make sure the spot welds holding the diff tubes in have to be ground smooth. i find that the higher the wheel stand, the quicker my run. As sson as i run the bar i lose .1. i set it so it just misses the rear valance (i know cause i have the dents to prove it!), for every inch i lower it i lose .06 to .1. i have run as quick as 1.33 60 ft and i am not having any spin or unloading issues through the launch.
last time i checked, he had some good photos on his site.
http://kenkeirracecars.com/
Ian
1968 Camaro
F/CM
Ian Hill is offline   Reply With Quote
Old 02-20-2012, 08:20 AM   #6
1320racer
1320racer's Avatar
Originally Posted by 40Coupe View Post
In order to hook on a marginal track I've got to set the front shocks full loose and full travel, then it goes bumper. I don't see an obvious downside to bars.
Does it really go on the bumper?
Whose shocks are you running?
FYI, I've run my Firebird without the wheelie bars using only the DA Afco's and travel limiters to control the wheelie.
You could always add ballast up front also
I just don't see the need on your car and I like relatively quick real street cars.
Old 02-20-2012, 10:41 AM   #7
40Coupe
Afco DA's front and rear.
'67 Camaro
1.25
5.77 @ 118
Old 02-20-2012, 11:18 AM   #8
1320racer
1320racer's Avatar
looks perfect to me. and you've got the right shocks. So if you can't calm the wheelie down by tightening the extension and adjusting travel limiters, just put 30 lbs. on the nose and it's done.
Maybe put the stock battery back up front does the trick.
Old 02-20-2012, 11:21 AM   #9
40Coupe
The battery is still up front. LOL
P.S. I was in 3rd gear at the tree praying for it to come down in that shot.
'67 Camaro
1.25
5.77 @ 118
Old 02-20-2012, 11:28 AM   #10
1320racer
1320racer's Avatar
Head wind helped that wheelie.
I wouldn't worry about. Hang some more weight up front.
How tight was the extension on the front shocks? I can go from this...
with the extension 1/4 turn from full tight
to this, with the extension at full tight...
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
