Old 02-20-2012, 08:20 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Ken Keir wheelie bars
Originally Posted by 40Coupe View Post
In order to hook on a marginal track I've got to set the front shocks full loose and full travel, then it goes bumper. I don't see an obvious downside to bars.
Does it really go on the bumper?
Whose shocks are you running?
FYI, I've run my Firebird without the wheelie bars using only the DA Afco's and travel limiters to control the wheelie.
You could always add ballast up front also
I just don't see the need on your car and I like relatively quick real street cars.
Old 02-20-2012, 10:41 AM   #2
40Coupe
Afco DA's front and rear.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 02-20-2012, 11:18 AM   #3
1320racer
1320racer's Avatar
looks perfect to me. and you've got the right shocks. So if you can't calm the wheelie down by tightening the extension and adjusting travel limiters, just put 30 lbs. on the nose and it's done.
Maybe put the stock battery back up front does the trick.
Old 02-20-2012, 11:21 AM   #4
40Coupe
The battery is still up front. LOL
P.S. I was in 3rd gear at the tree praying for it to come down in that shot.
'67 Camaro
1.25
5.77 @ 118
Old 02-20-2012, 11:28 AM   #5
1320racer
1320racer's Avatar
Head wind helped that wheelie.
I wouldn't worry about. Hang some more weight up front.
How tight was the extension on the front shocks? I can go from this...
with the extension 1/4 turn from full tight
to this, with the extension at full tight...
Old 02-20-2012, 12:16 PM   #6
1320racer
1320racer's Avatar
yea, but the cast iron heads aren't. There's some weight for you.
Old 02-20-2012, 11:55 AM   #7
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Damn that is a nice street car
Kevin
Old 02-20-2012, 02:07 PM   #8
40Coupe
Kevin
Thank you Kevin.
'67 Camaro
1.25
5.77 @ 118
Old 02-20-2012, 02:52 PM   #9
1320racer
1320racer's Avatar
so it's a secret as to what the shock's extension setting was on that pass?
Old 02-20-2012, 03:05 PM   #10
40Coupe
On that pass I had 7 degree of timing pulled out, front travel set to full (5.5") and front shocks were 10 or 13 clicks off soft (31 clicks total from full soft to full stiff stiff rebound)
One of two things were happening that day to me, either it went straight up as in the pass in the picture or with things tightened up to control wheelie it was blowing them off. There was no in-between whatsoever. No fun being on the starting line wondering if it's going to be a pedal fest or a burnout contest.
I want to be able to just set the suspension up to "let it eat".
'67 Camaro
1.25
5.77 @ 118
