I have been away from Stock Elim motors for a while and I wanted to ask a question. I was in a very reputable engine shop early in this week and I saw something that I wasn't aware of. They were machining a Stock Eliminator motor and was adding heavy metal to the crankshaft. They were adding heavy metal thru the crankshaft side of the counterweight. I had always operated under the conception that it had to be hidden. Comments please
charles |
Liked 695 Times in 206 Posts
My guess is that the counterweights have been turned down and heavy metal had to be added to correct the balance. Dyno
The rulebook says something about normal balancing.
If the pistons /rods/ rings are lighter than OEM, then the OD of the counterweights is the best place to take off the counter weight. The competent shops know how much to remove without having to put it back on, if you get my drift...so be forewarned..
Liked 6 Times in 2 Posts
An externally balanced motor like a 428 FE needs weight added to the rear crank counterweight to make it internally balanced. There are other examples as well. This is legal but you may have trouble with a light crank with added heavy metal being considered a "normal" balance job.
Dale Posnick |
Liked 8 Times in 7 Posts
sent a 66 289 out for an overhaul and balance (nothing special, just a stone stock rebuild)
as we don't do that at the shop and it came back with a swiss cheesed flexplate and mallory metal in the crank... what's a "normal" balance job? |
In Stock Eliminator, it is legal to use heavy metal in the crankshaft in order to internally balance an externally balanced engine. Other than that, heavy metal is not legal, as it falls outside of the "normal balance job" rule.
Alan Roehrich 212A G/S |
#7 | |
Let me re-clarify this , This was not a external convert to an internal. They were using a lighter crankshaft like a 305 and making it fit a 350. They were drilling and pressing the heavy weight into the side of the counterweight. In the older days, I was always under the impression that we had to install the weight and then we could weld it in and totally cover it so it could not be visibly seen that we had added heavy metal. Was I wrong in remembering that. charles |
which is why customers shouldn't be allowed to roam around the shop...
Jeff Lee 7494 D/S '70 AMX |
#9 | |
Your comment is quite well received. Since the motor was for a very good friend of mine. I just thought he and I would like to know if the motor was going to be legal. apparently if you were doing the work for a customer, you would not want the customer to know if it was legal or not. It was just a question with no harm intent. I most certainly do not think you would be building me an engine that I could not see until NHRA got to look at. charles |
I'm talking about people going online with a concern about somebody else's issue. The issue is between the customer and the shop. Maybe the customer wants it that way and maybe the customer doesn't want the world to know about it?
Conversely, a guy getting work done to his engine may be getting some really trick (and legal) procedure done and the customer takes this trick to the internet "trying to be helpful to the community" or maybe "I just want to make sure this is legal so I'll post it for 20,000,000 viewers". I see it all the time. Problem is, the engine building (by real masters) industry is dyeing and now some keyboarder just wiped out 40 years of R&D in about 40 seconds. That's why there are some engine builders that make the customer sign agreements that none of the contents will be shared with others. May be difficult to enforce in court but it does set the tone. Sorry, I'll get off that soap box now...
