Old 01-26-2012, 03:06 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default 68 Camaro - pushrod & which bore master cylinder?
I've searched and searched and cannot find these answers.
Strange sells a 1.031 and 1.125 bore master cylinder. Their webpage says "assume 4 wheel disc"...
I have 2 piston Baer front disc and stock rear drum brakes.
1. Which size bore master cylinder works best?
2. Will I have to modify the stock brake pedal push rod or just alter the length and move it to the top hole?
Thank you,
Clark
Old 01-26-2012, 07:14 PM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: 68 Camaro - pushrod & which bore master cylinder?
Thank you,
Clark
Clark;
I have very close to your same setup (different brand front brakes). I researched this exact question a few years ago. I was told to go with the 1.031 bore Strange MC. It came with a pushrod that I modified to work on my brake arm. Strange has good instructions on how to measure for the best pedal ratio...... on their web site..
Old 01-26-2012, 08:20 PM   #3
cad
cad's Avatar
Thanks. Also, a buddy told me that Quarter Max sells a U shaped bracket that can be installed as a secondary safety measure to ensure the brake pedal pushrod cannot fall out/down. Any info on that is appreciated.
Old 01-26-2012, 09:24 PM   #4
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Thanks. Also, a buddy told me that Quarter Max sells a U shaped bracket that can be installed as a secondary safety measure to ensuer on the bottom e the brake pedal pushrod cannot fall out/down. Any info on that is appreciated.
We made ours, its just a "Z" shaped piece of metal with a hole drilled thru it for the pushrod on the top flat, another on the bottom to bolt it to the firewall.
Took all of ten minutes to make
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 01-27-2012, 01:18 PM   #5
Dave1695
Liked 15 Times in 11 Posts
call Stainless Steel Brake Corp (800-448-7722) and order their one inch bore, Corvette style, cast aluminum master cylinder, part number 0476. I use one on my Camaro Stocker with their four piston comp front calipers and rear drums. it works great.
Dave1695 is offline   Reply With Quote
Old 02-01-2012, 06:09 PM   #6
Robert Swartz
Robert Swartz's Avatar
This is what we made. Was taken from a cell phone.
Name:	master cyl push rod align.jpg
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 02-01-2012, 10:12 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Cool Re: 68 Camaro - pushrod & which bore master cylinder?
You made that out of a cell phone??? You are talented! Jim
