Liked 69 Times in 32 Posts
Go to nhra competition rules ammendments!!!!
Ron Mattson 5015 STK |
Liked 3 Times in 1 Post
I would say that clears up a lot of questions!
Woodro Josey 2002 STK |
do the roller rockers have to be steel or is aluminum ok?
Liked 129 Times in 59 Posts
I think they still need to add one line -
Aftermarket rocker arms must have same ratio as OEM for engine horsepower claimed or OEM or Aftermarket rocker arms with any ratio permitted I do like the new rule about being able to reinforce an OEM steel rocker arm! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 719 Times in 220 Posts
Anybody have a brand name and part number? It would be nice to see what we need to buy.
67 Ford Fairlane F/SA 749 |
#7 | |
Liked 1,922 Times in 432 Posts
As of just now, there is no rocker arm category listed.
Alan Roehrich 212A G/S |
So if I show up with Harlan Sharp 1.7 roller rockers on my 327 I'm OK? Are they going to check the ratio?
Still a lot of "what if's"! Lew
Liked 269 Times in 99 Posts
Rocker Ratio is defined in your Engine Specifications in the guide.
I spoke to Nhra tech last friday and was told stock ratio, dont know why its not
on the new ammendment. As pointed out earlier it is in the engine blueprints and probably why nothing has changed ratio wise. I was also told there will not be a accepted or required list, Any commercially available unit that fits the outlined requirements will be just fine.
Ron Mattson 5015 STK Last edited by ron mattson; 01-20-2012 at 10:39 AM. Reason: changes |
