Guys and Gals,
I am about to purchase a set of injectors for my LT1 stocker motor. I think I know what lb. to get but I had a question if one brand is prefered over the other (ie. Bosch, Accel, Holley, etc..). Is there anything I should consider prior to purchase. Thanks for any help. Chris |
Liked 534 Times in 143 Posts
Check your PM.
Bosch. ACCEL injectors are made by Bosch now. Avoid cheap crap like Venom, etc. 30 lb is plenty big enough. I would use 24 lb at 60 psi if it were me.
Ed Wright 4156 SS/JA |
Liked 544 Times in 213 Posts
I bought Accel 24 lb injectors when I put my LT-1 together. I ran it at 55 lbs. fuel pressure.
The present owner has bigger injectors in it. I really don't think they are needed.....30lb'er's sound about right from the info I was able to gather from my data logger.... I had no probelm with the Accel's and had an Accel Gen VII ecu and data logger....and they are still in the car now....
I appreciate the help gentlemen. Hopefully see you in Baytown in March
As dumb as it sounds, the ford motorsports ones are good, and if you thumb through a mustang magazine, you can usually find them pretty cheap.
Chad Rhodes 2113 I/SA |
It isn't dumb. They are the ones we prefer and run.
#8 | |
Liked 7 Times in 5 Posts
regards, Roland |
The Ford Motorsports injectors are Bosch. Just another place to buy them.
#10 | |
