Old 12-18-2011, 02:08 PM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Q-jet and Holley
The air valve was probably not working properly.--- open all the way.
Or most likely you were trying to dyno it with the turbine installed on the carb.
I have experienced problems with some q-jets and the turbine. I think ours causes some air currents that the q-jet boosters/bleeds dont like. Look at your EGT's. I bet they were haywire from the Holley pulls. You might also check the fuel flow from the q-jet to the Holley. It could have been the N/S in the Q-jet not flowing enough fuel. Had that problem before, too. There are some hi-flow N/S available. Good luck
Adger Smith (Former SS)
Old 12-18-2011, 02:58 PM   #2
Reed Granrt
I agree with Adger. I just did a test on dyno 2 weeks ago and we removed a Holley and installed a Qjet with the dyno top hat and saw a significant drop in power. Air flow way down. Removed hat and power much closer.
reed
Reed Granrt is offline   Reply With Quote
