Old 12-16-2011, 07:41 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: Fuel temperatures
well, you always here of guys doing all kinds of stuff to their car for the headsup passes. i understand the light weight oil, but to all of a sudden start cooling the fuel, or intake would drastically change the fuel density therefore the need for a jet change...
also, B Aceves - you any relation to Mike Aceves from Hollister California? was a good friend i haven't heard from in about 6-8 years...at the time he was very much into drag cars and drag slot cars. i was going to visit California and stay with him, but it never panned out.
Ian
Ian Hill is offline   Reply With Quote
Old 12-16-2011, 11:57 AM   #2
Ed Wright
Ed Wright's Avatar
Smoking at start up has absolutely nothing to do with jets.
Ed Wright 4156 SS/JA
Old 12-16-2011, 12:11 PM   #3
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Ian
Yes Ian, Mike is my brother and is doing well, now married with two kids lol Small world huh !! Where are you from ? I will pass this info on to him im sure he will get a kick out of it. All his Drag slot stuff is sittin in a box including his world record car. Unfortunate all the tracks in this area are long gone. PM me if you want to chat some more.....thx
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 12-27-2011, 12:09 PM   #4
Mike Croley
The lower the fuel temp , the better . Just a few degrees won't make a huge difference in performance , but every little bit helps .
Restrictions in the fuel system will increase fuel temps , but not enough to cause a major loss in performance . Running the fuel line near any source of high heat will have much more of an effect .
As the fuel temp goes down , the density changes . So jet accordingly and then cool the fuel the same way and for the same duration before each run .
Mike Croley is offline   Reply With Quote
Old 12-27-2011, 09:37 PM   #5
Ed Wright
Ed Wright's Avatar
Ian, you don't have to re-tune the car for cold manifolds and cold fuel to help. You are mistaken there. Btw, you need to fix that black smoke at start-up. That tends to wash oil from the cylinder walls, which is a ring seal killer.
