Old 12-12-2011, 08:57 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Fuel temperatures
Every restriction creates heat. Regulators, bypass filters, elbows, depending on the brand, even fittings . Has anyone checked fuel temperatures between a running fuel system with a regulated pump and dead-headed regulator vs. a bypass regualtor loop style fuel system? i only run a one gallon cell in my stocker. i would assume most run 5 gallon cells, and if so i would figure a change in fuel tempurature would not be that appearant in that situation?
Ian
Ian Hill is offline   Reply With Quote
Old 12-12-2011, 09:31 AM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Fuel temperatures
just so you know the rules state a 3 gal. cell minimum. in a stocker, i never understood why, but that's what the book say's
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-12-2011, 10:26 AM   #3
Billy Nees
Maximum, 16 gallons, no minimum.
Billy Nees 1188 STK, SS
Old 12-12-2011, 11:09 AM   #4
Ed Wright
Ed Wright's Avatar
When I had my fuel cell built the rule book said 3 gal minimum for SS. Stock is different?
Ed Wright 4156 SS/JA
Old 12-12-2011, 12:30 PM   #5
Jeff Lee
Jeff Lee's Avatar
It was 3 gallons but I looked in my last printed copy under Stock and there was no mention anymore. But under Super Stock, it does mention that a fuel cell is 3 gallon minimum! I think NHRA has a misprint under Stock but I'm not calling!
Rule or no rule, I can go through 1/2-3/4 galloon from pit to pit. I sure wouldn't want to cut it that close using a one gallon cell. I have a 3.5 gallon aluminum and it's an upright.
Jeff Lee 7494 D/S '70 AMX
Old 12-12-2011, 12:50 PM   #6
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Ian, go to this link and make a phone call you wont be dissapointed http://product-engr.com/default.html
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 12-12-2011, 01:07 PM   #7
Billy Nees
I've got an old bud that races an Escort and has always had a 1 gallon cell in it.
Old 12-12-2011, 01:52 PM   #8
junior barns
Liked 20 Times in 14 Posts
None of the responses so far pertain to the question????
junior barns is offline   Reply With Quote
Old 12-12-2011, 02:05 PM   #9
Jim Craig
Liked 5 Times in 3 Posts
no answer yet because I doubt anyone has done an actual back to back -- it would take a lot of time and effort. Although, I do have some customers that have "back to backed" competitors' pumps with our comparable pump and have realized a 7 to 9 degree reduction in fuel temp. Having said that, the primary item you should look at.............to decrease fuel temperature in a fuel system, is to decrease the amount of fuel you're "driving" through the system.
Think about this for a minute since you've already listed the obvious restrictions within a given system. If your engine will only consume 50 gph of fuel, why are you killing the system with over 400...........you've got to do something with the excess, either within the pump (let's hope not, but some still use that style pump because a whole 'nother set of issues pop up there) or bypass back to a cell.
Jim Craig is offline   Reply With Quote
Old 12-12-2011, 02:44 PM   #10
junior barns
Just wandering myself. That's why I posted. Thanks
