Old 12-09-2011, 01:01 PM   #1
Mickey Whaley
Question Re: roller rockers
What is the final rule on rocker arms, anybody know???
Mickey Whaley is offline   Reply With Quote
Old 12-09-2011, 06:30 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: roller rockers
It appears to me, the rockers have to be the same configuration as stock ie; a Mopar small (early) and big block must still run the same shaft configuration, but the needle bearing roller tip rockers are allowed, must be same ratio as blueprint specs. I don't think NHRA intent is to allow machining the top of the head for T & D, Jessel, or such. I think the intent is a stud mount must still be a stud mount, a shaft must remain a stock shaft location. Some people will be affected in that the specs might call for a 1.5, and of course there are usually no numbers on the stamped steel or ductile iron(Mopar), and almost all of the aftermarket has the ratio on them. Might affect camshaft etc, and is very easy to look at by Tech Inspectors. That is what got me pitched earlier. Cam checked, but the specs say 1.6 and I had 1.65 and I went home. That's my story and I'm sticking to it.
Jeff Teuton 4022 STK
Old 12-09-2011, 07:47 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
I spoke with Mr. Gracia at PRI and what Jeff posted is pretty much it. He told me he had looked at the Harland Sharp rockers and approved them. Yellow Terra Rockers submitted a set while at the show. Apparently almost any rocker, aluminum, steel, needle bearing, sleeved or whatever kind of roller tip is ok as long as it will directly replace the stock rocker with no machining and check at stock ratio spec. MoPars must use and fit stock shafts for example. Jim
Jim Wahl is online now   Reply With Quote
Old 12-09-2011, 08:27 PM   #4
Mike Fuller
Liked 198 Times in 79 Posts
Thanks Jim!
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 12-09-2011, 08:36 PM   #5
Jeff Lee
Jeff Lee's Avatar
Bought mine from Comp Cams today!
Jeff Lee 7494 D/S '70 AMX
Old 12-10-2011, 03:42 AM   #6
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Wow. My stuff just became fully obsolete. And it hasn't seen the track yet...yay. Keep it up, guys.
Paul Merolla is offline   Reply With Quote
Old 12-10-2011, 05:52 AM   #7
Dean3870
x2
Dean3870 is offline   Reply With Quote
Old 12-10-2011, 09:27 AM   #8
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
If it isn't a 2010 or later model car the whole thing was obsolete anyway. Still capable of having a lot of fun and even getting a Wally though.
Pedigo Perf is offline   Reply With Quote
Old 12-10-2011, 12:12 PM   #9
danny waters sr
danny waters sr's Avatar
Who's rockers will pay ?
When IHRA did this Harland Sharp came on to pay....
Old 12-11-2011, 01:46 AM   #10
Liked 1,821 Times in 413 Posts
Clarified rule to be posted as early as next week. Well, what they call a "rule".
